#55587 by RParker
Wed Oct 12, 2011 11:49 am
Is there any way to insert a jpg (or bmp) to be able to view in O2C? Want to put client's (very complicated) logo/sign on a building.
#55593 by Nick Pyner
Wed Oct 12, 2011 7:12 pm
If you can do it as a signboard, it shouldn't be too difficult in o2c. A picture of the logo is treated the same as any bother texture - bricks, tiles etc. You just have a dedicated entity and stick it on. The picture below was not done in o2c but the procedure is the same. The logo was lifted from a web page. You can see it again on the sign in front of the yellow truck.
I don't think o2c does alpha channels so, if the logo is a complicated cutout, you are probably better of looking elsewhere. Unless this has been improved and I don't know about it, the other problem with o2c is the lack of repeatibility in the views. This means getting a view of the logo and a view of the model and putting them together in a graphics programme is very difficult even though you can solve the alpha channelling then. If you can't match the perspective properly, you are better off omitting the logo.
#55595 by RParker
Thu Oct 13, 2011 8:33 am
Thanks, was able to make it work.
Another question for next time: must textures be a square or is there a way to use a rectangular graphic?
#55597 by Nick Pyner
Thu Oct 13, 2011 9:17 am
I don't think they are required to be square and I'm sure I have made may own that were rectangular. I don't know why the commercial ones are typically square but, if it was technically required, I guess it would imply that they can only be used on square surfaces.
#55622 by Nick Pyner
Sat Oct 15, 2011 8:04 pm
Ahem...!
I wrote
Nick Pyner wrote:Unless this has been improved and I don't know about it, the other problem with o2c is the lack of repeatibility in the views.
Something was nagging at me when I wrote that, and I now realise that V14's o2c can store and recall views. This could be useful.....
#55623 by RParker
Sun Oct 16, 2011 9:49 am
Maybe it is because I'm still running on v12. When I import a jpg as a texture, it must be a square or the aspect gets boggled.
#55626 by Nick Pyner
Sun Oct 16, 2011 6:46 pm
I don't have the experience to comment and I wasn't aware of this. If that is your experience with V12, it could apply to V14 as well. I have my glass semi-transparent but I don't actually do any other rendering with o2c.
So, if you have this limitation with texture shape, did you just get lucky solving your original problem?
#55629 by Miguel Palaoro
Mon Oct 17, 2011 5:47 am
RParker wrote:Maybe it is because I'm still running on v12. When I import a jpg as a texture, it must be a square or the aspect gets boggled.
Hi Robert,
The o2c engine requires a square bitmap as a base texture. If you use as reference a rectangular bitmap, it will redimension it to bring as a square.
The trick is simply to "make-a-square" from a rectangular, using the bigger side as the square side, and filling up the smaller side of the rectangle with a plain black color, which is configured as 'transparent" on o2c settings, and locating the accurate "texture origin" for the correct bitmap placement.
HTH,
#55632 by RParker
Mon Oct 17, 2011 7:51 am
Thank you for that trick. I broke the rectangle into smaller squares and visually "stitched" them together. This will make it alot easier.
