The text in Door Symbols is not printing correctly
Posted: Mon Sep 11, 2017 7:18 pm
When I insert Door Symbols and then number them, the text is not printing at the correct line weight. The window symbols with text the same color and size are printing fine. I tried creating a plain circle of the same size as the door symbols and putting the text inside that but the same thing happened. Does anyone have any suggestions?
In advance, thanks.
Esme
I finally solved the problem. There was something wrong with the ending of the font which said ttf instead of shx. I erased all of the door labels, took all of the window labels which were printing fine and moved them to the door symbols. However, I would like to know how the endings got to be ttf and how you can change that back to shx.
Again, thanks
In advance, thanks.
Esme
Again, thanks
