When dimensioning tight areas using arrows (rather than tick marks), when the area is too small to fit the arrow heads, is there a way to have the arrows on the outside of the extension lines? And a related question, since the text won't fit within the extension lines either, what do you all prefer as an alternative location for the text (especially if it's within a string line)? I was taught to use a curve leader to 'attach' the dimension.
I've made a crude sketch to illustrate the point.
Thanks
Thanks
joshhuggins likes this
datacad dimension sketch 2.jpg (40.18 KiB) Viewed 7304 times
