#82837 by Gaddell
Mon Mar 11, 2024 2:01 pm
DataCAD 16
Windows 11 Home 64bit
Intel 12 Gen i7
Nvidia RTX 3070
16 GB Ram
2 - Sceptre 27" 4K Monitors
Problem:
DataCAD template window is too large on 4K monitor. ( see attached files )
It used to take up 10-15% of the screen. Now it takes up 25%.
Solutions Tried"
Updated all drivers and software.
Changed Windows to 150%. ( see attached )
Changed High DPI setting. ( see attached )
Changed DCADWin.ini ( see attached )
Changed DataCAD Program Preferences. ( see attached )
Would love any suggestions or help.
John R.
Solutions Tried
1080 P
4K
#82838 by joshhuggins
Mon Mar 11, 2024 5:23 pm
With Datacad closed, in your dcadwin.ini file, under the [SymbolBrowser] section, check to see what DockWidth= is set to. If it has a value, try reducing it, save the INI file and then restart Datacad to check.
#82839 by Gaddell
Tue Mar 12, 2024 8:17 am
Josh,
Thanks for the information.
The key i actually needed to change was in the [TemplateWindow] section.
Somehow i missed it while looking through all the section of the INI file yesterday.
The Width key was blank. [Width=]
Changed it to [Width=200] and it is perfect.
It took a few trys to get the number I wanted.
The [SymbolBrowser] key DockWidth was also blank.
While I was in there i adjusted it as well.
Thank you for the quick response and assistance,
John R.
Users browsing this forum: No registered users and 48 guests
