mouse speed #3837 by Jim Rowland Thu Jun 30, 2005 12:05 am I have a new cordless Logitech mouse. I have the speed and acceleration set fine for general use, but when in Datacad, it slows down. Is there still a setting somewhere to adjust mouse speed? I'm using version 11. Thanks in advance! Jim Rowland Username Jim Rowland Posts 11 Joined Mon Feb 14, 2005 1:21 am Location Bowser, British Columbia, Canada
This should be made into a Sticky... #3843 by Neil Blanchard Thu Jun 30, 2005 8:05 am Hello Jim: You need to go here: http://www.opendrivers.com/driver/213342/logitech-mouseware-advanced-settings-utility-1.1.0.1-windows-98-me-2000-xp-free-download.html Or, another site: http://download.myfreewares.com/TVRRNU5UUXk.html ...and download and install the utility. Run it and check off all the boxes (IIRC) and that should do it! Don't worry if this is not your specific mouse; it will work fine, since Logitech uses a "unified" driver. Sincerely, Neil http://neilblanchard.blogspot.com/ Username Neil Blanchard Posts 8362 Joined Fri Feb 11, 2005 11:24 pm Location Maynard, MA, Eaarth Contact YIM
