Dealing with PDF Files
Posted: Mon Jan 26, 2015 1:42 pm
I currently use Ver 14. It seems that PDF's have become the defacto standard for file distribution on most of my projects.
We are a Low Voltage systems integrator and mostly need to put devices on a floor plan.
What is the easiest way to use a PDF file as either a layer (inserted Bitmap or Image) or as a Xref?
Is this possible on the newer versions> 15, 16 or 17?
It seems I waste a lot of time importing DWG files (if I can get them) and cleaning them up.
I have done screen copys but they lack the resolution I need.
Seems there has to be an easier way to do this..
