#70398 by Mark F. Madura
Sun Dec 11, 2016 12:07 pm
We have recently determined that the display of curves may be adversely affected when the Main display on a multi-display setup is set to the tablet or laptop display, rather than the external monitor. In some cases, switching the Main display to the external monitor corrects the problem. This issue seems to be related to recent updates to Windows 8.1 and Windows 10. We are suggesting this work-around until we can determine a direct solution.
In Windows 8.1...
Windows 8 Context Menu
1. Right-click on the desktop and select 'Screen resolution'
- This will take you to Control Panel, Appearance and Personalization, Display, Screen Resolution
Windows 8 Display Settings Dialog
2. In the Screen Resolution dialog you can select the 'Identify' button to confirm the numbering of your displays.
- Usually, your laptop or tablet display is display 1.
3. Click on display 1 to highlight it.
- If you see 'This is currently your main display' then this is your Main display.
- Otherwise, if you see the option 'Make this my main display', it is not.
4. Click on display 2 to highlight it.
- This should be your external display monitor.
Windows 8 Make this my main display option
5. Check 'Make this my main display'
6. Click Apply, then click OK.
- You may need to sign out then sign back in for the changes to take effect.
7. The display of curves in DataCAD should now appear smooth.
In Windows 10...
Windows 10 Context Menu
1. Right-click on the desktop and select 'Display settings'
- This will take you to the Display section of System Settings
Windows 10 Display Settings Dialog
2. In the 'Customize your display' section you can select 'Identify' to confirm the numbering of your displays.
- If 'Make this my main display' is checked and greyed-out, this is your Main display.
- Otherwise, if you see the option 'Make this my main display' unchecked, it is not.
Windows 10 Make this my main display option
6. Click Apply.
- The change should take effect immediately.
