When I copy objects I've been teaching myself to use the "Copy - Drag" command instead of using the check box in the "Move" command because I can't imagine the amount of times I copied when I meant to move or moved when I meant to copy. For copy now I hit "C" then "F7" for drag. For moving objects I can now use the "m" then "F1" and I don't have to remember to look over at the the "and copy" button to see if it is green. So simple I'm embarrased to admit it!
I've been using this program for over twenty years and I am still finding ways to use it better.
