#5522 by Sinha
Fri Aug 26, 2005 5:23 pm
Thought you guys might be interested to know that, When making a custom drop down tool bar normally starts with A00, A01, A02 etc. In the midst just, miss one number that is:
A00=
A01=
A02=
A04=
A05=
See I missed a number (A03)....this will infact create a seperator line in the TB
Good luck!!
#5531 by Miguel Palaoro
Sat Aug 27, 2005 9:01 am
Good approach Sinha,
The problem I got here is that it prevents the show of the following icon/command in the order that was typed.
In your example it would replace the #A04 with the separetor line and show the #A05.
I'll need to test some more to get it working fine.
#5547 by Sinha
Mon Aug 29, 2005 10:19 am
This code is in my tool bar, You may copy it into your D11 Draw.dtb. Notice that I have totally missed out A02 and A07
[DIMENSIONS]
DropDownCount=8
Hint=Dimension Toggle
Icon=OFF_Dimen1
Hint00=Horizontal Dimensions
Icon00=OFF_HDimen
A00=^:^F3^F7^F8^D^F1^F1^S2^F1^Standard$^S0^
Hint01=Vertical Dimensions
Icon01=OFF_VDimen
A01=^:^F3^F7^F8^D^F1^F2^S2^F1^Standard$^S0^
Hint03=Extend Both
Icon03=OFF_Dimen1
A03=^D^F1^S8^F9^F2^F5^S0^
Hint04=Extend Line1
Icon04=OFF_Dimen2
A04=^D^F1^S8^F9^F1^F5^S0^
Hint05=Extend Line2
Icon05=OFF_Dimen3
A05=^D^F1^S8^F9^F2^F4^S0^
Hint06=Remove Both
Icon06=OFF_Dimen4
A06=^;^D^F1^S8^F9^F1^F4^S0^
Hint08=Xplode
Icon08=OFF_DimenX
A08=^;^D^F1^S7^
#5554 by Miguel Palaoro
Mon Aug 29, 2005 12:26 pm
Steve Baldwin wrote:...Something that I missed at first... Be sure to increase the "DropDownCount=X" number, to allow for the separator.
Great,
This was the missing tip. Thank you Steve. Great job Sinha.
