#79842 by msalink
Mon Jun 21, 2021 5:20 pm
With a recent hard-drive purge, I lost my keyboard shortcuts and feel cut off at the knees as a result. Does anyone have the MCR files with some of the shortcuts popularized by Evan Shu and in our Boston Dbug meetings? I'm thinking in particular of ones such as Alt Z for changing text contents, Alt D for Divide, and a bunch of others. Kicking myself for not having a print-out and a backup of all the dcad support files.
Mark
#79843 by Roger D
Tue Jun 22, 2021 8:30 am
Here's a copy of my file, letter's might not be the same, but use what you can.
A^·^È;^S5^¸^É
\\ A- Curve Menu
B^·^È^:^F4^S4^F6^1$^S0^F2^¸^É
\\ B- Template On/Off
C^;^F0^
\\C^;^F0^F0^S3^F2^$^S0^^:^S9^$^ change color of group
\\ C- Change
D^·^È^:^F8^F1^F1^É
\\ D- Dimensions
E^·^È^;^F6^¸^É
\\ E- Enlarge
F^·^È^;^F9^F1^¸^É
\\ F- Filet - Round Corners
G^·^È^:^F6^F1^f1^2$^¸^É
\\ G- Geometry - Divisions
H^170#^$^8#^S8^S2^F1^$^
\\ H- Change Text
I^;^I^$^S8^S0^
\\ I- Identify Set All
J^·^È^;^F9^F5^¸^É
\\ J- 2 line trim
K^·^È^;^F8^¸^É
\\ K- Group Link
L^170#^$^
\\ L- Edit Symbol Attribute at cursor, then pick next one
M^·^È^;^F4^¸^É
\\ M- Mirror
N;
\\ N- Can not, windows New File
O^·^È^;^S9^Cmd_Perf$^F4^F4^¸^É
\\ O- Curved Leader for notes
O^1054#^1051#^;^S7^S7^F6^S0^S6^S2^S3^F0^$^F2^
\\ Old one - O^;S3^S7^`^n^ ^.6$^S7^F1^n^$^S0^S0^ ^3.$^S7^F1^n^$^S0^S0^n^n
P^:^1067#^1024#^1068#^U$^;^:S5^S7^
\\ P- Plot - 1067-Pen Sort Off, ON => 1024# Smart walls 1068 WYSIWYG
\\Q^;^1016#^50#^$^$^
Q^;^1016#^F9^F4^$^$^
\\ Q- Trim to one line, 1016-One Line Trim by Entity On
R^·^È^;^S4^¸^É
\\ R- Rectangle
S^·^È^;^F5^¸^É
\\ S- Stretch
T^14#^S7
\\ T- Text, ParaText
U^·^È^:^F6^F2^¸^É
\\ U- Intersection
V^:^ú^Ä^F6^F3^F8^
\\ V- Offset
\\V^·^È^;^S9^Dynoff^$:^F6^F3^F2^¸^É
W^·^È^;^F9^F7^¸^É
\\ W- Weld Line
X^:^F7^
\\ X- Measures
Y^·^È^:^F8^F1^S8^F1^S2^¸^É
\\ Y- Change Dimension Text Location
Z^·^È^;^S5^S6^S1^¸^É
\\ Z- Edit Polyline
#79844 by joshhuggins
Tue Jun 22, 2021 2:21 pm
Here's mine you can pick thru. :D
Code: Select all// Arrows
// Old Arrows = A^1054#^;^S7^F1^S7^F8^S0^;^S6^S2^F9^0.05$^F0^F1^S0^S1^50$^S2^1$^S3^F1^S6^
// New Arrows = A^1054#^;^S7^F1^S7^F8^S0^;^S6^S2^F9^0.3$^F0^F1^S0^S1^6$^S2^1$^S3^F5^S6^
// Bisect Angles
B^b^F1^
// Change Text Contents
C^170#^$^;^F0^S8^S2^F1^$^
// Dimension
D^;^S7^F1^S7^F8^S0^:^F8^F1^
// Enlarge
E^m^S0^F6^
// Fillets
F^48#^
// Offset
// Ä Geometry/Offset Dynamic Off
// ú Turn Offset Perpendicular On (Usually this is on from last use, this is just incase it got accidentally turned off before, needed for masking, uses last entered value)
// Geometry, Offset, Mask, Entity, All On = :^F6^F3^F5^F1^F1^S8^
// Bezier, Point, Text, B-Spline, Dimensions, Symbols, Xrefs, Scroll Forward = F3^F5^F7^F9^F0^S1^S2^S3^S7^
// Sym Attribute, Exit, Exit, Perp Distance (Off), Perp Distance (On ready for input)
G^Ä^ú^:^F6^F3^F5^F1^F1^S8^F3^F5^F7^F9^F0^S1^S2^S3^S7^F3^S3^S0^S0^F2^F2^
// Hand
H^31#^F3^
// Identify Set All
I^·^È^;^S1^$^S8^S0^É^
// Join Lines
J^52#^
// Link
K^·^È^;^S1^$^S8^S0^É^32#^F1^$^
// Layer Manager
L^141#^
// Mirror
M^m^S0^F4^
// New
N^:^S6^F1^
// Object Snap
O^30#^
// Plotting
P^:^S5^
// Quit
Q^:^S9
// 3 Point Arc
R^1072#^;^S5^F2^
// Stretch
S^m^S0^F5^
// Text
T^ñ^;^S7^S7^F5^S0^;^S6^S8^F3^0.0$^F7^1$^F8^F5^S0^S9^F6^S0^
// ClipCube
U^143#^
// 3D Views
V^106#^S9^
// Window Extents
W^:^S8^F1^
// Point to Point
X^26#^F4^
// Directory
Y^34#^
// Change Menu
Z^;^F0^
