If you edit the Dcadwin.ini file in \datacad12 and scroll down to the [o2cViewer] section, then down to Remember Last View=TRUE (change from False), each time you open the o2C Viewer to set up a view, then close the viewer, it will re-open at the view you were last at. It's almost like a GTV for O2C and if you have set up materials and lights it actually looks better than a Quickshade. It's also quick as you can keep going in and out as you edit/change your model to quickly see the changes. It won't remember the +/- camera zoom, though you can quickly pick these to get the same viewpoint.
You can also set the background color to Black or whatever you want so it opens to your preference each time.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
