Hello,
The list of new MSP features in v12 is pretty impressive, and if you are not already using them, you should give 'em a try!
Select the MSP details by clicking on them, and then move them (helps especially if there a lot of details and/or if the names are too cryptic)
See the detail name what scale they are set for by hovering over them (the detail in question is shown with a heavy outline!)
Use Control-Right Click on each detail to:
Pen Tables can be set up to change for different plot scales -- so the same color line can be plotted at different widths.
And the "biggie": Bind One sheet or Bind All MSP sheets to a new layer, which you can then export to DWG. The new layer gets named what the sheet is named, and each detail is made into a symbol; each of which has just the layers that are used in the detail, and any Clip Cube is duplicated as a Symbol Clip.
And don't forget about the "old" features in MSP: use custom insertion points (with or without the grid) to precisely align a row/column of details, and if you use self-references (or XRef's) you can overlay details on the plans or sections, and only have to add the new text, etc. You save having to draft something more than once -- and your drawings will be more accurate, because you are clipping out a piece of the overall building. This helps especially if the main drawings get changed -- the changes will show up in the detail, too!
- *Rename
*Update (it to the current view)
*Make Curr(ent view -- this makes the detail act like a GTV, which can help in old drawings)
*Rotate
*Pen Table (each detail can have it own Pen Table; by scale or custom)
