I'm currently running v14 on XP. Looking now to upgrade OS to MS 8 or 8.1 Has anyone had any issues running v14?
Steve J.
Sydney
Steve J.
Sydney
sjohnoz wrote:Hi Nick
I take your comments onboard! It was also my need to upgrade to a new computer as my old Pentium was old and tired.
I also realise that I will need to upgrade some accessories as you have done. Have you had any problems in deactivating and activating to a new computer?
Neil Blanchard wrote:What I have heard is they skipped Windows 9 because it is too close to 95 and 98 and the code naming was too confusing. I have heard good things about Windows 10.
Nick Pyner wrote:sjohnoz wrote:Hi Nick
I guess a Pentium, by definition, is probably due for retirement, but that is insufficient grounds for changing the operating system. I have upgraded to XP from Vista on a laptop, and from W8 on a desktop. I have since found that my Intellimouse Explorer can be persuaded to work under W8, so I might get W10 but there is no hurry.
Activate/deactivate is not a problem and I do it whenever I go on the road. I use a separate desktop icon running a BAT file to do this. This sits in the Datacad17 folder.
dcadwin.exe/ACTAUTO "licenseID:xxxxxxxx--password:xxxxxx"
dcadwin.exe
dcadwin.exe/DEACTIVATE "yes"
MtnArch wrote:The main pratfall I see with this, Clayton, is that if for some reason your internet connection isn't working when you try to open DC (no matter how reliable it is, there ARE glitches sometimes) you can't open the program until it can run home to mama server and verify that it's okay to start up.
Clayton Taylor wrote:The below I just cut & pasted from DC for that scenario:-
If you do not have an Internet connection, select Activate Manually. Type the License ID and Password into the appropriate fields, and then click Continue. The activation dialog will display User Code 1 and User Code 2, which you will transmit to the DATACAD LLC representative by telephone or email. The representative will then generate Activation Code numbers and transmit that information back to you. After typing it into the appropriate field, click Continue to complete the process.
However if no Internet connection, then e-mail may also be out..!!! Sometimes telephoning may also be difficult, time-zones/language etc, may be a temp SMS TXT code could be generated to let you RE-ACTIVATE it for a period of time & when it sees a connection is available, a pop-up interface could nag you to death to make a final RE-ACTIVATION protocol. Or if non of the above is doable, just let it be RE-ACTIVATED of a period of time with a known password that could be generated from the last RE-ACTIVATION or whatever.
I realise there's call to protect software to genuine users who have paid for their license etc. but equally I think it shouldn't be to heavy about it.
Over & out,
Clayton.
Users browsing this forum: Google [Bot] and 49 guests
