We currently have to set the DataCAD program to view or not view nested XREFs. Since we use nested XREFs to reference one floor on top of the other, we turn off the nested XREFs in the tools menu to speed up the refresh and also keep from accidentally having their layer turned on when we plot. The problem is some of our projects have nested XREFs that are a part of the final plot. When we open those files, half of the file is missing until you eventually remember view nested XREFs is turned off.
It would be nice to have one or both of these options to view nested XREFs.
1) By File: Set the "View Nested XREFs" by file. It would be like the linetype, hatch pattern, etc. where whatever was selected before you closed the file is the default when you open that file in the future.
2) By XREF: This would be a setting in the reference manager where you can choose to "View Nested XREFs" that are in the file you are referencing. It could be a button in the reference manager where the "Refresh", "Reload", "Bind", etc. are located.
I hope that makes sense.
