thank you
Mark Bell wrote:A small wishlist - when using dimensions/change text position allow the option to see the text rather than just the bounding box/outline as it will allow better placement of text/dims on the sheet in tight areas. Thanks.
wvar wrote:Mark Bell wrote:A small wishlist - when using dimensions/change text position allow the option to see the text rather than just the bounding box/outline as it will allow better placement of text/dims on the sheet in tight areas. Thanks.
A top idea Mark
Mark Bell wrote:A small wishlist - when using dimensions/change text position allow the option to see the text rather than just the bounding box/outline as it will allow better placement of text/dims on the sheet in tight areas. Thanks.How did we miss this one huh? Great wish.
Mark Bell wrote:Another wishlist to add to both the standard Set Perspective View and Sunshader is Shift lens. This allows the optical 'distortion' seen where a building tapers off and can sometimes look like its falling by straightening the outer edges to align vertically.
