If I switch to Firefox then right click on the image, click open image, it comes up?
Oswalt Construction
Box 111
Birchwood WI 54817
Box 111
Birchwood WI 54817
joshhuggins wrote:I wish we could store light sources inside symbols.
joshhuggins wrote:The ability to Change, More, Hatch, Hatch Type, (all settings from Hatch Type Menu). This way we can apply hatch type settings independent of the hatch menu which forces you to set the correct hatch settings for each different hatch "type".
joshhuggins wrote:It would be nice to be able to create multiple color translation files that we would be able to load at the import and export dialogs. Right now it's pretty straight forward to create/adjust the default.tbl using the DWG TrueView to view a clients ctb file and then adjust the translation table, the clincher is having to swap out the single tbl file each time, and keeping them stashed away in different folders. The swapping out of the default.tbl in the file system is a little much for some users. Maybe adding a path option \support files\Translation Tables?
Color Mapper
Color Translation Export
Color Translation Import
Users browsing this forum: Google [Bot] and 104 guests
