When working in 2D I tend to construct lines to mirror copy object ( as in the attached picture). I then delete these lines after use. I was wondering if within the mirror command options, we could have a mirror between two points. Therefore I just snap to two point and the mirror line is formed mid way between these points. (noted on attached picture as snap 1 and snap 2) This would save drawing the construction lines and then deleting them.
Mirror lines.png (52.36 KiB) Viewed 17394 times
Many thanks
Bruce
Dell XPS 8300. Windows 10
Intel(R) Core(TM) i7-2600 CPU @ 3.4GHz. 16 GB RAM. AMD Radeon R9 200 series, 32'' inside leg
Bruce
