#58376 by Mark Bell
Wed Oct 10, 2012 12:55 am
DataCAD 15 wishlist :D
1. Add the ability to use Measure/incl./excl. angles on smart walls - presently these commands only work on 2D line entities,
#58412 by Mark Bell
Mon Oct 15, 2012 9:40 pm
Wishlist for the updated Sunshader/NX:
1. Allow transparencies to fills/alpha matt to make background colors invisible,
2. Add a toggle or two to streamline the ability to fit an image to a polygon or vice versa. DataCAD's Visual Reality which came out with v8 made this very easy where all you had to do was select a image (person, tree, car etc.) and drop it into the program and it automatically assigned a polygon to suit the images dimensions so that using the example below, the palm tree would be centered to the polygon and at the correct scale.
#58414 by joshhuggins
Tue Oct 16, 2012 12:13 am
Mark Bell wrote:Allow transparencies to fills/alpha matt to make background colors invisible
If possible would be nice to get support for 32 bit PNG with actual transparent alpha channels vs. an additional seperate alpha channel images or 1 bit color masking.
#58422 by joshhuggins
Tue Oct 16, 2012 6:44 pm
The above would be able to do just that! Purdy neat huh? :D
#58435 by Mark Bell
Wed Oct 17, 2012 4:36 pm
Another wishlist item for KNOCKOUTS:
Add the ability for knockout's used on text (with or without a border) to:
1. include a color fill behind the text as part of the knockout box/border,
2. allow different border effects (similar to PowerPoint etc.) ie. shadows, border thickness, line style, line color etc.
3. have the ability to ignore existing color fills but still knockout linework or hatch patterns - this helps remove the white cutouts around text over fills on printed drawings which can often detract from the presentation of the drawing. In these instances the preference would be to knockout line work/graphics but ignore bitmaps and fills when toggled on,
4. add the ability to customize the shape of the knockout - similar to the polyline editing features,
5. add the ability to change to preset knockout shapes, ie. circular wit horizontal line for door reference tags, hexagonal for window reference tags, etc. so the knockouts can also be used as text tags for door/window schedules/elevations and other notes.
6. add the ability to include 'smart tags', ie. when numbering a multi-storey carpark presently each parking bay is numbered using typical text. If the design changes and spaces are added/deleted, then each bay needs re-numbering. Add 'smart tags' so that a user can use a 'number tag' that increments with each new tag placed on the drawing. This allows each bay to be numbered with each new tag incrementing accordingly. If bays are later added/deleted then all 'smart number tags' adjust accordingly so that the total numbering remains accurate.....and I don't have to go back and re-number several hundred bays :D Multiple 'smart tags' should be able to be used so each tag may require its unique name when creating the tag. The tag field should be editable so it can be used for say hotel room or apartment type numbering etc. with perhaps a later option to printout or create a quick spreadsheet/list?
#58479 by Neil Blanchard
Wed Oct 24, 2012 1:52 pm
If you make a self-reference using a GTV, it would be great to have it automatically linked to that GTV. (Or does it do this already?)
I seem to remember something similar already in place for XRef's, so that when you open the file from the Control-Right Click menu, you get the GTV used in the instance?
#58499 by Neil Blanchard
Fri Oct 26, 2012 10:54 am
When I use the Tangents to rotate the cursor, it would be lovely to have the Show X/Y indicator show up, so I can use the Shift-Snap to use Get X/Y and not have to guess which axis is which. Or, at least the Show X/Y toggle should be in the Tangents menu so I can manually turn it on?
I use Direction/Distance so I think the Show X/Y should be the indicator for me and for anybody using Relative Cartesian. If you are in the Relative Polar mode, then the Show Zero option would make sense, I think?
#58503 by REX PEET
Fri Oct 26, 2012 5:09 pm
....well maybe not the best thing, but certainly way ahead of anything in second place. That would be multi-scale plotting or p text.
#58504 by Paul Nida
Fri Oct 26, 2012 6:25 pm
Neil Blanchard wrote:When I use the Tangents to rotate the cursor, it would be lovely to have the Show X/Y indicator show up, so I can use the Shift-Snap to use Get X/Y and not have to guess which axis is which. Or, at least the Show X/Y toggle should be in the Tangents menu so I can manually turn it on?
I just wish it worked the way it used to. When positive x was always in the upper right quadrant. Then I always knew which way was x and which was y. The way it works now sucks in my opinion.
#58506 by Mark Bell
Fri Oct 26, 2012 7:22 pm
Neil said "Did I ever say that GTV's are the BEST thing since the invention of CADD?" - I'll second this, DataCAD's combination of GTV's, MSP's clipcubes, xrefs, keyboard flexibility et al is what makes DataCAD one of the best all round systems available....
#58768 by joshhuggins
Wed Dec 05, 2012 7:42 pm
Similar to how we are able to suppress smart wall hatch & fill in Xrefs, adding the ability to suppress normal hatch and fills in xrefs via Ctrl+Right Click would be a nice speedup option.
Users browsing this forum: No registered users and 134 guests
