Arc/Tangent does this!
Arc/tangent is close or is the same if the line ends are the same. If not, then it is tangent only at one end.
Thanks though.
Woody
Thanks though.
Woody
If you have Object Snap\Tangent toggled on, it will work if you start on the shorter line. To start with the longer line, you can use the Shift-Snap Get X or Get Y to finish, and then 2-Line Trim to connect the arc to the shorter line.
