It would be nice to have stringline dimensions for Align. Sometimes, things are out of alignment, but we still run a line of dimensions at an angle. Then when something is moved, the creating of new dimensions along that same line is really a struggle. Currently, I use Rotated dimensions, but since I am always looking for the "easy" way, having that in aligned dimensions would be nice.
Woody,
If the first dim "locked" in the angle, then I could see this working.
I have posted a wish elsewhere to have horizontal and vertical dims taking on the angle of the cursor. So, if you use B Tangents to rotate the cursor, if horizontal dims would align with the "tilted" X axis, and vertical dims aligned with the "tilted" Y axis, then we would both be happy, I think.
