3D Slabs/Polygons and Edit/Show/Hide Edges + Boolean
Posted: Fri Apr 21, 2017 5:22 am
After using Boolean subtract on 3D polygons the resultant 3D entity displayed all the triangulated vertices making up the shape. Using Show/Hide was able to remove these so the entity could be used in a plan view without all the diagonal lines.
Wishlist: Add a toggle to the Boolean command that automatically Hides all internal vertices/edges leaving only the perimeter edges visible -
