Render Settings / Sunshader / Filters - maintain selection
Posted: Tue Jan 09, 2018 11:33 pm
Currently, selecting Render Settings/Entity Type filter then say cylinders to exclude it from being imported into Sunshader, will provide a cleaner looking image when shadows are turned on. However, after exiting Sunshader the selections are reset and needs to be done again each time Sunshader is used. I use SS almost as much if not more than O2C as it gives a better image to check the design progress. Having DataCAD remember the selections made in the Render Settings would be most useful.
