3D trim-to entity
PostPosted: Sat Feb 03, 2018 6:15 am
by Mark Bell
1. Add the ability to select the surface of an object as the trim-to plane, then select a 3D entity to trim up to the selected surface.
2. Also have this feature apply to smart walls. This would allow walls (smart of vertical slabs) to easily/quickly extend up to a roof plan, underside of stairs or beam etc. rather than having to model a vertical slab on top of a smart wall, then add vertices and stretch into position to map the profile of the entities being extended up to. Adding this ability to both smart walls and standard 3D entities/slabs would certainly improve modelling time on projects.
