Wishlist - xref
Posted: Fri Sep 09, 2005 1:38 pm
I wish:
1. In the Xref Manager, that the files would be in alpha order, not inserted order. When trying to do a group redefine, at times it is hard to pick out the same names when scattered in a list of 20-30 files.
2. That when you select an xref file to open from within the referencing file (using the right button, file select), that the xref opens to the current settings of the xref. (layers on, view scale, etc)
