Smart Arrows - structurel
PostPosted: Thu Oct 31, 2019 4:00 am
by John Daglish
Could a structural span arrow be added to the arrow types for ordinary and smart arrows ie, https://www.archtoolbox.com/images/repr ... t-span.png
Re: Smart Arrows - structurel
PostPosted: Thu Oct 31, 2019 9:10 am
by Paul Nida
John Daglish wrote:Could a structural span arrow be added to the arrow types for ordinary and smart arrows ie, https://www.archtoolbox.com/images/repr ... t-span.png
I think you can create a symbol for the arrow head in smart arrows, that might help you out some. But I wouldn't mind being able to have a double headed arrow.
PostPosted: Thu Oct 31, 2019 9:28 am
With all the macros and options, I am surprised it's not available. But I still do a dumb arrow, and then mirror 1/2 arrow around the center line of the arrow line.
PostPosted: Thu Oct 31, 2019 2:48 pm
John, can you post an image of the kind of arrow you would like?
PostPosted: Fri Nov 01, 2019 4:21 pm
by John Daglish
Hello Neil
Click on the link in my first message that shows a png image of the arrow type.
PostPosted: Fri Nov 01, 2019 6:23 pm
A symbol arrowhead for smart arrows is the way to go for this. Can't do double headed arrows but can set the symbol and the do two arrows in opposite directions to get the symbol to flip.
I was going to suggest that if you really needed dumb arrows to have this, to setup a macro to draw the smart arrow and the convert the polyline to lines but the symbol head disappears when you do that so that's not much help. :?
PostPosted: Sun Nov 03, 2019 7:49 pm
by MtnArch
What I've done in the past is to use a dimension without any witness lines (I usually use full open arrowheads) - this gives you the double-headed arrow line without having to either mirror a smart leader/arrow or do one manually.
