Recently I worked with a clients drawing and they use Bearings as their default Angle Type. When I changed that to my default Dec Degrees I had to stop and figure out what was happening because 0 degrees was still pointing up the screen.
It's a very minor thing to set the Start Angle every time (I get a file, set to Dec Degrees to work on it, reset the Start Angle, set it back to Bearings to send it back) but is it possible to have the Angle Type set to the DEFAULT DIRECTIONS when selecting an Angle Type?
For example when I select 'Normal' can we get it to reset 0 to be going to the right? If Bearings was previously selected 0 is still pointing up the screen.
DataCAD Normal Angle Type.jpg (13.62 KiB) Viewed 32486 times
DataCAD 22.02.14.02 BETA on my own build Gigabyte MOBO rack mounted Windows 10 Pro 22H2 x64 i7 920
