add to supported bitmaps
Mon Feb 27, 2023 1:43 pm
Add .heic file types for supported image files.
Re: add to supported bitmaps
Mon Feb 27, 2023 2:47 pm
by Mark F. Madura
Hi Roger,
You can do this in DataCAD 22.02 BETA. Set Files of Type to
High Efficiency Image File (*.heic;*.heif;*.heics) format.
MFM
All Image Files
Mon Feb 27, 2023 2:56 pm
where is that setting, all I see in the insert menu is
Mon Feb 27, 2023 3:51 pm
by Mark F. Madura
Do you have the New SPB-Fill features enabled?
In DCADWIN.ini:
[DEBUG]
New SPB-Fill=True
MFM
Tue Feb 28, 2023 1:20 pm
that was it.
Was set to false, was that the default setting when it was added to the .ini file?
Tue Feb 28, 2023 1:47 pm
Made the change, then when doing a MSP layout, file closes/crashes.
Change back to False, and can do MSP layout again.
Tue Feb 28, 2023 1:57 pm
by Mark F. Madura
Hi Roger,
The installer sets this key to False. Can you send the drawing that crashes in MSP to
help@datacad.com?
Thank You,
MFM
