Just a small thing, but how about when using the “1 new layer” command to create a new layer, DataCAD would then ask if you want to add that layer to the current active GoToView layer set?
This would be a welcome feature. Probably the majority of the time
new layers I add need to go into the current GTV. But what if you're
zoomed in or not at the exact extents as the GTV you want? Maybe
it could add the layer to the last GTV selected.
