#7601 by boofredlay
Thu Nov 10, 2005 5:08 pm
Specifically Extend and Trim.
I would like to see a global trim/extend feature.
Could go something like this:
Command: Trim / Global
... now anything you click will trim to the nearest entity. If you hold down shift (ctl, alt... whatever) it will toggle to Extend.
This should include arcs, polylines, splines and ellipse as well as lines.
This is of course all lines have to be in the same plane.
#7611 by Philip Hart
Fri Nov 11, 2005 9:13 am
Are you asking for a One Line Trim that figures out by itself which line to trim to and which side is the "outside?"
#7618 by boofredlay
Fri Nov 11, 2005 11:39 am
Exactly, however it would also figure out if it is between two lines and trim (partial) that line between the two.
By simply clicking the line where you want it to "disappear".
Now I know the ability to select the line you want to trim to is very powerful, I just think that this add on would make clean-up easier in some cases.
#7626 by Steve Scott
Fri Nov 11, 2005 1:51 pm
Have you tried free trim? It's located under Cleanup as S5 FreeTrim.
You can do an area around all your entities (or mask specific types
when you select) as the trimming entities, then snip pieces out as you
like. Be aware that when you select "begin" to start that layer search
doesn't apply. All entities are fair game. Yeah, it's a workaround
with only partial usability, but it's a handy feature.
#7641 by boofredlay
Fri Nov 11, 2005 5:08 pm
Yeah I have tried "Free Trim" and it is not very "Free".
I found that it does not allow you to clip to symbols. That does not make it very free to me. :roll:
I just stopped using it.
#7678 by Miguel Palaoro
Mon Nov 14, 2005 6:36 am
boofredlay wrote:...I would like to see a global trim/extend feature.
Hello Eric 'Boof',
You are suggesting something like a 'free trim' with a pre-selection of all entities in the drawing ?
...If you hold down shift (ctl, alt... whatever) it will toggle to Extend.
This is a very interesting approach. I like it.
Same layer, Lyrsearch toggle on/off... Let's elaborate some more on this.
I like very much the idea to use Shift and Control keys among our commands. It is very handy and memory related with other Windows applications.
#7719 by boofredlay
Tue Nov 15, 2005 10:20 pm
You know, this is the most handy trick I found out when using AutoCAD.
Just select Trim (or Extend), then right click (or enter) to make it global and start clicking away... hold shift and your are inverting the command. I use it every time I am in AutoCAD.
#7734 by joshhuggins
Wed Nov 16, 2005 11:35 am
I do remember using that in Autocad, and it was very handy indeed. I would like to see more Shift/Ctrl key use to enhance our commands too.
