I would be great if a context box popped up for other icons so if I select the Draw Arc's icon a context box opens up? It would be a great for all the icons.
Hello Curt,
I am afraid not to understand your suggestion, but If I did, you already can do it today.
It depends only on your creativity and 'some' manual effort.
You can use one of the supplied files on '\Support files\toolbars' any with the suffix .dtb to create your own toolbar files.
.DTB is a text file that can be attached to any menu later
Go to the 'View/Toolbars/Context' and make the choices.
Hope this helps,
