In relative polar, the distance is relative, but angle is not. From anyone line drawn, relative angle will to be criated.
Is it possible real relative polar with relative angle?
Arthur Emmanuel wrote:In relative polar, the distance is relative, but angle is not.
Paul Nida wrote:...If you want to draw a line at an angle relative to another line, then use tangents to rotate your cursor to the angle of the line you are drawing relative to.
Miguel Palaoro wrote:I must disagree with you, because the type of angle Arthur needs is another angle type, that increases clockwisely, and takes into account the direction of the last lag, and it must be set to its 'opposite' bearing.
It is the typical use on a land survey poligonal drawing, when you use a theodolite to right-walk over the border of the measured land.
You can't use 'tangent' because it would bear to the direction where to was drawn the last line. And this is not the case.
I am sure this kind of angle type would help for those who works on the area.
Users browsing this forum: No registered users and 154 guests
