If you Identify an associative hatch the F0 appears, click on it and it takes you to a menu listing out the settings of the hatch with it's own Set All at the bottom.
AJ Blasio (aka Tony)
Windows 10
Intel CORE i5
8GB Ram
Windows 10
Intel CORE i5
8GB Ram
Yes, Tony has it right. The last sequence works when it is a hatch pattern that you're clicking on.
Ah!
I see, and anything else it just gives a null cause there is no command and then goes through the other ones again. No big deal.
Neat!
Neat!
Pay it Forward!
Yes. And the result is Identify/Set Everything except Z height and Z Base. The only downside of this is if you are doing lots of 3D modelling and want to use Alt+I to pick up Z info.
Users browsing this forum: No registered users and 74 guests
