Hello Dave,
Among things I'd love to see in the promised improvements on the Object-snap features are:
a) Tangent Line among two circles or arcs
If you are 'arriving' to a curve (or circle) and want to tangent it, you can find this point today, normally. My wish is to 'start' from a tangent point to reach another tangent point. Since this starting point is 'virtually' not known yet, today this is not possible.
b) Tangent Arc among two arcs
Example: when you are designing a swimming pool with curved tangents borders, this is a required feature for the precision of design.
Suggestion for this Improvement
Using the 'Shift' key hold down you would be allowed to select from the context menu for the desired obj_snap selection, like this:
DataCAD would 'catch' (identify) the Entity itself (say an arc or a line), but not yet the object snap 'Point'. This would be hold-up until you specify the second end-point:
Then DataCAD would draw the entity (line) at the definitive position, realocating the temporary starting point to fit the original choice (in the example, tangent):
This could also address a problem of today, when you got the 'circ or arc' Object Snaps settings turned ON (quadrant, tangent, center), these settings does overlap the linear osnaps like endpoint, intersection, etc., and vice versa. I guess the option to choose among a list of obj_snap settings can handle satisfactorily the subject.
