I know this may sound crazywackfunky, but it's just the way we do it. (it may be wrong so, let me know.)
In the door swing command...I enter the size of the door as you typically
would. ("Jamb in" is not on)
In the windows command however, I draw the windows as you typically would, but with "Jamb In" turned on.
Then say, the client adds a door.
I forget "Jamb in" is on and now the new door(s) is/are smaller than the others.
is there a setting in ini that I can change?
