Sometimes while drawing in one GTV it becomes necessary to use
a second GTV to, let's say, draw a line or other entity on the active
layer in the first GTV. Example: let's say you're on the first floor
GTV and need to draw a ceiling line on a ceiling layer that is under
a wall above on the 2nd floor GTV. Currently, one must turn on a
certain layer on the 2nd GTV, snap to it, then draw the line. And it
is a pain sometimes to find just the right layer, yada yada yada.
How about a feature that allows switching GTV's yet keeping your
current active layer active (and on, of course) with all the other
layers in the 2nd GTV turned on? In essence it would be adding a
GTV to your active layer. Then it could revert back to the previous
GTV with the same layer active. What say?
Steve Scott
