Paul Nida wrote:Josh, you didn't hit any of my buttons. I just wanted to point out that not everyone works the same way, as you already know. Just because one person doesn't use a particular part of the program doesn't mean no one else is. I also think that if you are proposing to get rid of a button that others are using, you should give a reason and possibly a suggestion for a better use.
Hi Paul,
I am kinda pointing not to remove that button...but to blend both into one...
See for eg.
On D11 select the "linetype" button....these are lines that are currently in the dwg, but if I have to add another, the "manage" and "createline" is already found there....I won't have to exit and go elsewhere to load a line....
All I am sayin' is do the same with "Hatch"....loading and selecting in the same....
Like it has made easy to load and select lines...it will do also to the hatch
An Easier load and select....
