#799 by Miguel Palaoro
Sat Mar 05, 2005 10:09 am
Hello,
Is possible to add an internal function code to "Isometric" in 3D Views ?
I wish to have a transparent root to this command, which helps a lot to show the 3D model. A direct access code could add easiness to the stream 2D edition.
#1827 by Joanna_3E
Tue Apr 12, 2005 9:05 am
Hello Miguel,
I don't know if it helps you, it isn't internal code, but it works fine for isometric view:
A=^Ě^Č^V^F6^S0^¸^É
#1841 by Miguel Palaoro
Tue Apr 12, 2005 12:26 pm
Thank you Joanna. Your tip was very useful. I've noted now that the access to the 3D Views menu using the 'V' is transparent, otherwise then the 'y' that I was using.
This is mine:
A=^y^F6^
I'll change to this, according with your tip:
A=^V^F6^
I discharged the other codes (after this two) because I want to keep the 'globe' on screen, allowing some circular navigation at this point.
Many Thanks,
Users browsing this forum: No registered users and 119 guests
