Hello,
When you need to rotate several entities, located in different positions, but with the same angle, you need to set the rotation "center" to each entity itself, before selecting it.
How about the possibility to create an optional 'quick' rotation routine, which would allow to save one click on the feature ?
It would work as this:
If you use this optional feature, when you select an entity, it would use that place where you clicked on the entity, as "the" rotational center. In several times you just need to roughtly rotate a text string or a symbol object, and it would help a lot.
And, in the case you need precision, if you use the 'middle button' to select the entity, the rotation place would be that one precisely.
