It would be nice to have a "Batch Export" function that would let you select the properties (i.e. all or on layers, export references, etc.) and then select a bunch of files and let them fly. Since so many engineers use that other CAD software, we have to export a bunch of drawings and it's very time consuming to have to open each one and export them.
It's not a batch file, but I assigned CTRL+D to a spot in the menu file that eliminates a few steps.
Export
DWG
All Layers
On Layers|ctrl+D|
When I select CTRL+D all I have to do is hit ENTER and sometimes answer Y to overwrite an existing file.
Like I said, it's not a batch file, but if you have all your settings made it speeds up the process considerably.
Export
DWG
All Layers
On Layers|ctrl+D|
Dick
DataCAD user since version 2
