When you insert a bitmap, it would be nice to be able to just grab the file and click once to insert it in its' original size rather than have to scale it every time. We use several bitmaps from the code books and we have to plot to see if the size is correct, then fix it, etc., etc.
It should be possible if you added a "dpi" selection when you insert or have a function within DCAD that can read the dpi of the inserted bitmap. That way it is to scale, quick and easy.
