Two things that would be nice in the Polyline menu. First, if it could remember your settings from last time you used it like most other menus. When we are using polylines for electrical connections, we have to constantly go back and turn off the "Closed" option because it defaults to that rather than the last setting you used.
The other thing would be to either remember the setting you used previously for 3 Pt Arc or 2 Pt Arc so you don't have to choose it every time you want to draw a line.
