#12737 by Greg Blandin
Wed Jul 12, 2006 10:17 am
I wish there was a way to unload embedded hatch patterns. I will be working from an old drawing and have deleted out all the hatch patterns and used new ones. To be able to convieniently manage the patterns, I would like to delete out the ones that arn't in use. Keeps things cleaner and easier to read.
Thanks
Greg
#12738 by Graeme
Wed Jul 12, 2006 10:28 am
I could be wrong here but I think you want to Purge the file.
#12739 by joshhuggins
Wed Jul 12, 2006 10:41 am
In our Dcadwin.ini file you can check the settings in the following area:
Code: Select all[Purge]
LineTypes(Manual)=TRUE
Symbols(Manual)=TRUE
Layers(Manual)=TRUE
HatchPatterns(Manual)=TRUE
LineTypes(Automatic)=TRUE
Symbols(Automatic)=TRUE
Layers(Automatic)=FALSE
HatchPatterns(Automatic)=TRUE
A value of true in any of the (Automatic) settings will remove unused entities when a drawing is closed & automatically purged. The (Manual) settings will purge when using Purge from the File drop down menu. Adjust the values as you need, save the ini file restart Datacad, open and close your drawing and you should be set. It will not remove entities types/definitions that are still being used.
#12740 by Neil Blanchard
Wed Jul 12, 2006 11:49 am
Hello,
Actually, the Manual settings can be changed right in the File/Purge dialog...
If you want to "preload" any standard linetypes and/or hatch patterns -- or especially empty layers -- in your default files, then you do not want to have these automatically purged.
Last edited by Neil Blanchard on Wed Jul 12, 2006 11:58 am, edited 1 time in total.
#12741 by Greg Blandin
Wed Jul 12, 2006 11:52 am
Thanks Josh...that worked wonders.
Graeme - I had tried to purge the file, but it did not work. I was pretty sure I was doing it the right way, but now that I think about it, I might have been backwards.
Thanks again all!
Greg
#12818 by Sinha
Tue Jul 18, 2006 1:04 pm
But What If I load a pattern but decide not to use it, Will those Josh's codes still work?
#12820 by Greg Blandin
Tue Jul 18, 2006 3:14 pm
Sinha wrote:But What If I load a pattern but decide not to use it, Will those Josh's codes still work?
It will unload any hatch not found in the drawing.
