I consider that some topics would better need to be treated in the architecture question to facilitate the work.
Windows in arched wall.
Substitution of windows and doors in the model.
Automatic tables in the windows and doors .
Automatic roofs and wooden profiles.
Top walls that if adjusts to the inclined plans of the roof.
Wavy profiles of roofing tiles.
Spirals of diverse profiles.
Studies of insolation, indicating local, day and schedule.
As Cad, some points could be improved.
Tranparent Bitmaps with transparent control of 0 - 100%.
Textures in degrade.
A field that had the names of the related view and layers, with possibility of new combination.
Boolean for all the entities with surfaces.
Exportation of the model with the materials in formato.3ds.
A system to render more powerful in parallel with o2c.
Identify cursor of the type of selection.
Visible points of snap.
Option of selection of command for entity, for example, when click in one polyline, the command polyline would be activated.
Identification of group on the screen with color.
To hide lines as an environment hide in the screen, to be able itself to draw directly in hide. Drawings from ambient hide.
One viewport more than active of the same archive.
Extrude polygons.
Free viewer of .aec.
Extrude polygons.
Last edited by Arthur Emmanuel on Tue Nov 14, 2006 12:05 pm, edited 4 times in total.
