Ability to remove lines From 3D elevation of smart walls
Posted: Tue Mar 10, 2009 9:01 am
It would be nice if we could choose lines we don't want shown in elevation.
For example, I have a 4 line wall where line 1 is the brick, line 2 is the exterior of the stud wall, line 3 is the insulation inside the wall & line 4 is the interior of the stud wall. When I pull up the front view, the insulation line type renders around the walls so the wall type is not usable in elevation. It does this after using the "remove hidden lines" function as well. If I could choose to not show line 3 in elevation then I could use my wall type in plan and it will look right in elevation.
