#50715 by Mark F. Madura
Tue Oct 19, 2010 4:07 pm
Code: Select all{
  DCAL for Delphi Program: LyrRename
library LyrRename;
uses
  // Delphi Units
   sysutils,
  // DCAL for Delphi Header Files
   uconstants in '..\Header Files\UConstants.pas',
   uinterfaces in '..\Header Files\UInterfaces.pas',
   uinterfacesrecords in '..\Header Files\UInterfacesRecords.pas',
   urecords in '..\Header Files\URecords.pas',
   uvariables in '..\Header Files\UVariables.pas';
{$e dmx}  // dmx is the extension for DCAL for Delphi Dll's
// The values stored in the records you define here will be rememberd
// between dispatcher calls because they are pushed onto the command stack
type
   renamel = record
      state: asint;
      searchstring: str255;
      replacestring: str255;
      case byte of
         0: (getp: getpointarg);
         1: (dgets: dgetstrarg);
   end;
   prenamel = ^renamel;
function SearchAndReplace(const str: string; searchstring: string;
   const replacestring: string; casesens: boolean = false): string;
var
   p: word;
   done: boolean;
   newstring, tmprepl, tmpsrch: string;
   cd, charsdeleted: integer;
   res: string;
begin
   if (length(searchstring) = 0) then begin
      result := str;
      exit;
   end;
   if not casesens then begin
      newstring := ansiuppercase(str);
      searchstring := ansiuppercase(searchstring);
   end
   else begin
      newstring := str;
   end;
   res := '';
   done := false;
   charsdeleted := 0;
   while not done do begin
      p := pos(searchstring, newstring);
      done := (p = 0);
      if done then begin
         res := res + copy(str, charsdeleted + 1, length(newstring));
      end
      else begin
         tmpsrch := searchstring;
         tmprepl := replacestring;
         // Get the characters up to the text to be replaced and append them
         // to the resulting (post-replace) string.
         res := res + copy(str, charsdeleted + 1, p - 1);
         // Now calculate the number of characters
         // up to *and including* the text to be replaced.
         cd := p + length(tmpsrch) - 1;
         // Chop off the text up to and including the text to be replaced,
         // so it can be used for the pos() call in the next loop
         delete(newstring, 1, cd);
         // Increment total number of characters deleted.
         inc(charsdeleted, cd);
         // Append the replace text to the resulting (post-replace) string.
         res := res + tmprepl;
      end;
   end;
   result := res;
end; { SearchAndReplace }
// Check the replacement string for invalid characters
function Valid_Characters(name: shortstring): boolean;
const
   // These characters are not allowed in Windows file names.
   forbiddenchars: set of char = ['?', '[', ']', '/', '\', '=', '+', '<', '>',
var
   len, i: asint;
begin
   result := true;
   len := length(name);
   for i := 1 to len do begin
      if (name[i] in forbiddenchars) or (ord(name[i]) < 32) then begin
         result := false; // invalid characters found
         exit;
      end;
   end;
end; { Valid_Characters }
// Then use this on the new layer name prior to committing it to the database
{ 0 = ok }
{ 1 = invalid character in layer name }
{ 2 = name already used }
{ 3 = name too short (0 chars) }
function Check_Layer_Name(name: shortstring): asint;
var
   temp_name: shortstring;
   rlyr: rlayer;
   plyr: lgl_addr;
begin
   name := trim(name);
   if (length(name) = 0) then begin
      result := 3; // too short
   end
   else begin
      result := 0;
      if not Valid_Characters(name) then begin
         result := 1; // invalid character
      end
      else begin
         plyr := lyr_first;
         while lyr_get(plyr, rlyr) do begin
            plyr := lyr_next(rlyr.addr);
            getlonglayername(plyr, temp_name);
            temp_name := trim(temp_name);
            if sametext(temp_name, name) then begin
               result := 2; // duplicate layer name
               exit;
            end;
         end;
      end;
   end;
end; { Check_Layer_Name }
procedure LayerRename(searchstring: str255; replacestring: str255);
var
   lyr: layer;
   newname, lyrname: shortstring;
   lyrschanged, lyrsskipped: asint;
   howmany: str255;
begin
   lyrschanged := 0;
   lyrsskipped := 0;
   lyr := lyr_first;
   while not lyr_nil(lyr) do begin
      getlonglayername(lyr, lyrname);
      newname := SearchAndReplace(lyrname, searchstring, replacestring, false);
      if Check_Layer_Name(newname) = 0 then begin
      // if no invalid characters are found...
         setlayername(lyr, newname);  // ...then update the layer name.
         if not ansisametext(newname, lyrname) then
            lyrschanged := lyrschanged + 1
         else
            lyrsskipped := lyrsskipped + 1;
      end
      else
      lyr := lyr_next(lyr);
   end;
   howmany := inttostr(lyrschanged) + ' layers changed.  ' +
      inttostr(lyrsskipped) + ' layers skipped.';
   wrterr(howmany, true);
end;
// Main Function (Re-entrant State Machine)
function Rename_Main(act: action; pl, pargs: pointer): wanttype;
// The values stored in variables you define here will not be retained
// between dispatcher calls because they are not pushed onto the stack
var
   retval: wanttype; { asint; }
   l: prenamel;
begin
   l := prenamel(pl);
  { Section 3: Aagain - Return to menus and wait for input }
   if act = aagain then begin // Re-entrant section
      case l.state of
         1: begin
          // If a key was pressed or a menu button was selected...
               if l.getp.result = res_escape then begin
                  case l.getp.key of
                     f1: { Search }
                        l.state := 2;
                     f2: { Replace }
                        l.state := 3;
                     s9: { Begin }
                        begin
                           lblsinit;
                           lblson1;
                           LayerRename(l.searchstring, l.replacestring);
                        end;
                     s0: { Exit }
                        l.state := 0;
                  end;
               end;
            end;
         2: begin // search string
               if l.dgets.result = res_normal then begin
                  if Valid_Characters(l.searchstring) then
                     l.state := 1
                  else begin // try again
                     wrterr(l.searchstring +
                        ' contains an invalid character. Please re-enter the search string.',
                        true);
                  end;
               end
               else if l.dgets.result = res_escape then begin
                  if l.dgets.key = s0 then
                     l.state := 1;
               end;
            end;
         3: begin // replace string
                  if Valid_Characters(l.replacestring) then
                     l.state := 1
                     wrterr(l.replacestring +
                        ' contains an invalid character. Please re-enter the replacement string.',
                        true);
                  end;
               end
                     l.state := 1;
               end;
            end;
      else
         l.state := 0;
      end;
   end;
  { Section 2: Afirst - Tasks to perform only once }
   if act = afirst then begin // Initialize local state and other variables
      wrterr('Layer Renamer Version 1.0 by Joey Nips', true);
      l.state := 1;
   end
  { Section 4: Alast - If your macro has been interrupted by user action }
   else if act = alast then begin
    // If you're going to get blown off the stack...
    // (i.e.) the user pressed a hotkey,
    // then this is your last chance to clean up temporary data.
   end
  { Section 1: AlSize - Allocate memory on stack for local variables }
   else if act = alsize then begin
      setlocalsize(sizeof(l^));
   end;
   if act <> alsize then begin // Action section
      case l.state of
         1: begin
               wrtlvl('Rename'); // Set Menu Title
               lblsinit;
               lblset(1, 'Search', 'Enter the string search string');
               if l.searchstring = '' then
                  lblmsg(1, 'Enter the string search string')
               else
                  lblmsg(1, 'Current search string: ' + l.searchstring);
               lblset(2, 'Replace');
               if l.replacestring = '' then
                  lblmsg(2, 'Enter the replacement string')
               else
                  lblmsg(2, 'Current replacement string: ' + l.replacestring);
               lblset(19, 'Begin');
            // lblset(20, 'Exit');  //In DCAL for Delphi use lblson1 instead
               lblson1;
               wrtmsg('Enter the search and replacement strings or select begin.');
               getpoint(l.getp, retval);
            end;
         2: begin
               lblsinit;
               lblson1;
               wrtmsg('Enter the SEARCH string: ', true);
               calldgetstr255(l.searchstring, 255, l.dgets, retval);
          { Dispatcher will call as soon as it has control, go to Aagain: 2 }
            end;
         3: begin
               lblsinit;
               lblson1;
               wrtmsg('Enter the REPLACEMENT string: ', true);
               calldgetstr255(l.replacestring, 255, l.dgets, retval);
          { Dispatcher will call as soon as it has control, go to Aagain: 3 }
            end;
      else
         retval := xdone; // Don't go back to Aagain
      end;
   end;
   result := retval;
end;
// End of Main Function (Re-entrant State Machine)
function main(dcalstate: asint; act: action; pl, pargs: pointer)
   : wanttype; stdcall;
begin
   case dcalstate of
      xdcalstatebegin:
         result := Rename_Main(act, pl, pargs);
   else
      result := xdone; { Necessary }
   end;
end;
exports
   main; { This is the entry function that will be called by DataCAD.
  All DCAL Dlls will have this function. }
begin
end.
