forum.datacad.com • View topic - lyr_isLocked bug?
lyr_isLocked bug?
PostPosted: Sat Jun 02, 2018 9:13 pm
by dhs
Re: lyr_isLocked bug?
PostPosted: Mon Jun 04, 2018 10:30 am
by David A. Giesselman
What does the Create method for your TLyr class look like?
PostPosted: Mon Jun 04, 2018 1:34 pm
by dhs
PostPosted: Mon Jun 04, 2018 1:47 pm
David,
I'm not sure why it would be giving you unpredictable results. If you modify your code to call "lyr_get" you could inspect the .group field of the Rlayer record. If that field is equal to -1, the layer is not locked.
PostPosted: Mon Jun 04, 2018 4:29 pm
by dhs
Thanks Dave,
Your suggestion of inspecting the .group field of the layer record is working as expected.
PostPosted: Mon Jun 04, 2018 4:40 pm
PostPosted: Wed Jun 06, 2018 5:50 pm
by dhs
Happy send you the entire project source if you want to debug it etc to see why it is returning incorrect values, but the workaround you suggested seems to working ok.
I was working on a simple Text Replace macro as an exercise to re-familiarise myself with D4D. (It is now completed and available for download from my web site for anybody that is interested.) It will only process normal text entities, as I don't think MText or PText are accessible from DCAL or D4D (?). Any chance that these entity types will be accessible by D4D in the future ?
Rgds,
David H.
