INI Section Key Order
PostPosted: Mon Aug 06, 2018 4:20 pm
Does Datacad ever use a hard order for keys in a [SECTION] of an INI based file? The Sections are just looked up and the KEY addressed directly? Was going to cleanup values of some of my values and wanted to double check to see if Datacad might be doing something special when reading/writing keys.
Re: INI Section Key Order
PostPosted: Tue Aug 07, 2018 6:11 am
by David A. Giesselman
The keys within [Sections] are not order dependent.
