D4D lyr_read bug ?
Posted: Fri Oct 05, 2018 3:46 am
I have a problem with the lyr_read call in the following code:
the lyr_read on the last line of the code snippet is returning a value of -5 (and hence the function result is false).
Some D4D notes I have suggest that -5 means that the layer file is not found, but I know that it is created as I can see it in FIle Explorer. The same notes suggest that I need to add the '.dlf' extension to the file name passed to lyr_read so I tried that but it produced a fault 19 error from 736 when I did so.
I believe that the layer parameters passed to this funciton are ok: fromlyr is the (not nil) result of either a lyr_first or lyr_next call, and tolyr is the address returned by a successful lyr_create call.
Is anybody able to offer any advice on the use of the lyr_read function? This bit of code is pretty much converted straight from some existing Classic DCAL code which works just fine.
David H.
Code: Select all
function CopyLyrContent (fromlyr, tolyr : lyraddr; zshift : double) : boolean;
var
tempfilename : str255;
addr : entaddr;
mode : mode_type;
ent : entity;
begin
result := true;
getpath (tempfilename, pathtmp);
tempfilename := tempfilename + 'dh_lmtemp';
if fileexists (tempfilename + '.dlf') then begin
if not deletefile (tempfilename + '.dlf') then begin
result := false;
exit;
end;
end;
result := (lyr_write (fromlyr, tempfilename) = 0);
if result then
result := (lyr_read (tolyr, tempfilename, false, false) = 0);
David H.
