forum.datacad.com • View topic - Create an entity on another Layer (D4D)
PostPosted: Tue Nov 06, 2018 3:07 pm
by dhs
Hi,
To create an entity on a layer that is not the current layer in Classic DCAL I have previously saved the current layer, switched to another layer to create the entity, and then switched back to the saved layer... similar procedure to copy any entity to another (non-current) layer.
This is not possible in D4D as the Lyr_Set procedure does not work. I seem to recall that simply changing the layer in the entity record does not work, so can anybody tell me a method to copy an entity to another layer in D4D ?
David H.
Re: Create an entity on another Layer (D4D)
PostPosted: Tue Nov 06, 2018 4:02 pm
by David A. Giesselman
PostPosted: Tue Nov 06, 2018 5:53 pm
by dhs
PostPosted: Mon Oct 21, 2019 7:39 am
by sam_bar
PostPosted: Mon Oct 21, 2019 1:06 pm
by dhs
