#13238 by devinder
Mon Aug 14, 2006 9:21 am
I have not tried in a DCAL program, but this should work.
Code: Select alltype
{This is DataCAD's internal record for display settings of TTF. Not to be modified}
    TDisplayTTF = PACKED RECORD
                          dooutline  : Boolean;
                          dofill     : Boolean;
                          OutlineClr : aSInt; {Valid values -1 or 1..255}
                          FillClr    : Integer; { Valid values -1 or 1..255 or RGBValue+1000}
{any -ve value means inherit color properties from the entity ie. ent.color}
                   END;
procedure inserttext(txtpoint : point; str : str255);
var
  dispttf : TDisplayTTF;
  ent : entity;
begin
   ent_init(ent,enttxt);
   ent.txtpnt:= txtpoint;
   ent.txtsiz := savevar.txtsiz;
   ent.txtang := savevar.txtang;
   ent.txtslant := savevar.txtslnt;
   ent.txtaspect := savevar.txtaspt;
   ent.txtBase := savevar.basez;
   ent.txtHite := savevar.hitez;
   ent.txtfon := savevar.fontName;
   ent.txtwinfont := savevar.txtwinfont;
   ent.txtstr := str;
   ent_add(ent);
   if savevar.txtwinfont then
   begin
      atr_init (atr, atr_str);
      atr.name := 'WFFontName';
     {DataCAD's internal attribute name that keeps Windows TTF FileName}
      atr.str := 'Times New Roman';
      if atr_add2ent(ent,atr) then
      begin
         atr.name := 'TTFProp';
          {DataCAD's internal attribute name that keeps TTF Display colors/settings}
         dispttf.dooutline := true;
         dispttf.dofill:= true;
         dispttf.OutlineClr:= -1;
         dispttf.FillClr:= 1000 + RGB(255,128,0);
         setlength(atr.str,sizeof(dispttf));
         move(@dispttf,atr.str[1],sizeof(dispttf));
         atr_add2ent(ent,atr);
      end;
   end;
   ent_draw(ent, drmode_white)
end;
Users browsing this forum: Google [Bot] and 33 guests
